LandmarkCreating a plant line
Command
Workspace: Path
Plant Line
Design Suite: AEC > Plants
Landmark: Landmark
The Plant Line command creates a freehand plant line along a line, polyline, or polygon. It can be used to represent a single undefined plant, line of plants, or general plant mass. No specific plant symbol information is included in a plant line; use the Landscape Area tool if defined plant areas are necessary (see Creating landscape areas).
To create a plant line:
Select the object (line, polyline, or polygon) with the Selection tool.
Select the command.
The Plant Line dialog box opens. Suggested values are based on the selection’s perimeter.
Parameter
Description
Segment Length
Maximum length of each plant line segment; longer segments create a rougher plant line appearance
Thickness
Maximum perpendicular distance of each segment; a higher thickness value results in a rougher plant line appearance
Corner Types
Specifies the type of corner to create between segments; each type produces a different plant line effect
Delete original
Removes the object that forms the basis of the plant line
Select the desired plant line parameters. The plant line is created. If desired, apply colors, textures, and other attributes to the plant line with the Attributes palette.
The Attributes palette
